US Acoustics 2300 Amp
USA-2300F
2x300w into 4 Ohms. 2x400w into 2 Ohms. Bridgeable to Mono 1x800w into 4 Ohms. Fan cooled. Signal to Noise Ratio: Better than 108dB. Built-in Low Pass Crossover continuously variable (40-400Hz). THD: 0.015%. Low Level Input: 150mV-3V. Slow start up/ Anti-Thump Circuit. Protection: Thermal, Short Circuit and DC Protection with LED indicator. Screw terminals. New MMT™ Regulated Power supply. Bass Boost +18 dB @40Hz (Size: 6 3/8"W x 19 3/4"L)
Has some nice specifications, I have never heard of any problems with people using US Acoustics.
Are you buying this without a warranty?.
no, it was started by the same guy that started hifonics back in the day (when it was good) and founded usamps
EDIT:along with several other amp companies
good amp.
Well basically you are looking for an amp that puts out around 800 watts RMS at 2ohms for 200bucks total.
The cheaper Korean made classD's are a good choice for sub amps if you are on a tight budget, you can get them pretty cheap brand new with a decent warranty and since the circuit board parts are more common, repair times are shorter (no special order stuff) that is in the event that one ever breaks down.
SQ is not a primary concern with subamps as even cheaper amps can play 10 to 400 hz with no problem, you just need to make sure that it has the actual output capability you need at the ohms you plan on running, I would buy somthing rated at a greater RMS than you need to ensure that you are getting the power you need(all the cheaper companies use the asian made curciut boards).
Here is some ebay listing for monoblock sub amps under 200 dollars-
http://electronics.listings.ebay.ca/_Car-Amplifiers_Mono-Car-Amplifiers_Mono-1-Channel-New_W0QQa10244Z10425QQa14ZQ2d24QQa31300Z31355QQalistZa14Q2ca31300Q2ca10244Q2ca3801QQcatrefZC3QQcatrefZC6QQcurcatZtrueQQfposZQ5AIPQ2fPostalQQfromZR2QQfsooZ1QQfsopZ1QQftrtZ1QQftrvZ1QQgcsZ1548QQpfidZ1928QQpfmodeZ1QQpriceZ1QQreqtypeZ2QQsacatZ64570QQsadisZ200QQsaprchiZ200QQsaprcloZ0QQsaslcZ3QQsbrftogZ1QQsocmdZListingItemListQQsofocusZso
Actually I'm looking for a 4 ohm or 1 ohm amp that pushes at least 600 W RMS. I just won a DEI 600D on eBay, so that should be plenty for me //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif. I didn't even think I was gonna win the auction hehe.
perfect //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
abcheng
abcheng
Atlanta, GA
chinny
BP1Fanatic
BP1Fanatic
