us 2000
Would I want to run my amp @ 2 or 1 ohm itll be the us 2000 amp thanks
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif Due to the impedence of your subs, 2ohm isn't even an option. There is no way to wire those subs to 2ohm. 1ohm isn't really an option either, but you'll need to make sure your amp is stable down to 1ohm.
I assume you have a US Amps USA-2000? If so, I'd just wire each sub's coils in parallel (so that each sub is 1.5ohm), then just put one sub on each channel. So, each channel would have a sub on it, running at 1.5ohm.
if i did this will I hurt the amp or the subs ?
the amp is stable down too 1 ohm .. Thanks for the help .. IF i do wire the subs amp this way will I loose any power from the amp .. If this isnt a good idea what amp would u suggest .. Subs are 750 RMS and 1500 Peak Id want atleast 1500-2000 watts
TimDIve
TimDIve
de
Bring97
michigan born
    May 14, 2026
michigan born
    May 14, 2026
