You heard wrong, man. You should definitely fuse that bad boy, even if it is a short run. You never know.okay from what i heard, the fuse should match the amp, my amp has (3) 40A fuses, which is a total of 120A. So i got (3) 0 gauge ANL fuse holders with (3) 120A fuses. I will be running a second battery, a small Stinger SPV20, so i plan on putting 2 fuses between the front and back battery within a foot. then the other will go from the + alt to +bat.
also i heard you do not need to fuse the amp from second battery if your amp has built in fuses.
well i can do that, so how many fuses do i need between that one run of 0 gauge going from the front of the battery to the back battery?You heard wrong, man. You should definitely fuse that bad boy, even if it is a short run. You never know.
so i need to get rid of my 120A fuses and get 300A?The fuses are protecting the wire. Fuse to the capacity of the wire.
Fusing a 0 guage line at 120 amps is limiting the wire. 0 guage is designed to carry 300 amperes. If your amp is fused at 120 and that is the total max draw of the entire system you are ok. If you add more power in the future you will need to adjust your fusing accordingly. What I would do in this situation is fuse the 0 gauge at 300, and fuse within a foot of your amp to 120. Even if the amp has on board fusing. Think of the fuses as a safety net. You are protecting your cars electrical, and your equiptment from a short circuit. The point being where your fuses are needed is install dependent.okay from what i heard, the fuse should match the amp, my amp has (3) 40A fuses, which is a total of 120A. So i got (3) 0 gauge ANL fuse holders with (3) 120A fuses. I will be running a second battery, a small Stinger SPV20, so i plan on putting 2 fuses between the front and back battery within a foot. then the other will go from the + alt to +bat.
Yeah, see i have a 5 channel amp, and its all i need. Its on board fusing is 120A, i have a standard battery up front, but the one i also have in the rear is a stinger spv20. so basically my setup will look like this, and everything will be safe right?Fusing a 0 guage line at 120 amps is limiting the wire. 0 guage is designed to carry 300 amperes. If your amp is fused at 120 and that is the total max draw of the entire system you are ok. If you add more power in the future you will need to adjust your fusing accordingly. What I would do in this situation is fuse the 0 gauge at 300, and fuse within a foot of your amp to 120. Even if the amp has on board fusing. Think of the fuses as a safety net. You are protecting your cars electrical, and your equiptment from a short circuit. The point being where your fuses are needed is install dependent.
**** so i need 4 lolyou need another fuse between the batteries.....one at the front and one at the rear.....
the idea is that any power source has no chance of being unfused to ground.....in your drawing, if the main wire from bat to bat was to ground in the middle, the front half would be protected, and the rear battery would short**** so i need 4 lol
