Upgrading system
Alex81
Currently only have Clarion NX 500, 4 Alpine R 6 x 8 powered by JL 4 channel. Had a W7 powered by JL mono
500 but it sounded bad and got rid of it.. I am certain it was the box in hindsight
The set up isn't any better than the stock Mach 460 that came in the Mustang.
I want to have a setup with very loud mids and highs that aren't overpowered by the bass. I have ordered the Pioneer 4400 to replace the disappointing Clarion, which is not the same quality as a decade ago like so many of
the companies with great tradition.
What kind of speakers/amp combo could I use for very loud highs, and would 1 quality 10" sub be enough?
I used to know what was the best quality, with so many selling out and the newer ones
I just don't know anymore.
Thanks for any assistance
Currently only have Clarion NX 500, 4 Alpine R 6 x 8 powered by JL 4 channel. Had a W7 powered by JL mono500 but it sounded bad and got rid of it.. I am certain it was the box in hindsight
Hi! I do not think replacing the Clarion on Pioneer you get a significant difference in sound quality!
Yes Clarion not what HX-D1, HX-D2, 7xx series, but on a pioneer and not ODR sound quality!
Do not expect the quality of the multimedia reciver!
If you want only the volume and average quality, then go!
If good quality, the best 1-din!
In 5x7 sizes are not good things with the midrange reproduction!
Yes, the lower midbass is nice, but midrange is lame!
As well, and twitter!
But twitter - they are bad!
It is better that the thread to see other, I like soft home type tweeter, Morel MT-23, Eton CX280V, EOS AL267, but they do not have the volume of a special, or put double or use a professional acoustics, such as P. Audio, Sound 18....
5x7 R can put two pairs in the front doors, the doors prokleivat good!
And to make 3 ways or or 2 with homemade midrange/twitter!
W7 - sub is good, more suitable for listening to rap, with deep bass, the electronics are not very good!
W6 me more like speed!
500/1 has small power, only for 8 inch W7!
W7 - love to eat power!
10-inch subwoofer is not very loud!
I understood everything except this.
The reason I'm replacing the Clarion, which wasn't that bad considering the deal I git on it and the NAV
is because the processor went out on it. It still plays CD's you can't change tracks or do anything else. Also did quite a bit if research
on the new Pioneer decks. Aside from the "I'm not that loaded" units the Pioneer's seem to be the best with a slight edge
over Kenwood with the releases of the 4400 and 3400.
2001 Mustang GT with Mach 460. It's hard to believe but those stock amps were actually decent and the
factory speakers drivers and magnets are bigger than the alpines. The alps sound a have better bass, and barely noticeable better sq
but overall it felt like the stock was better
Are you saying to upgrade the tweeters? I'm wanting to do that, but need to take them out tomorrow. Apparently it is
a weird size and some sort of mod needs to be made to add an aftermarket. Haven't seen the stock units listed size anywhere
10's are the largest sub you can fit in the Mustang. Was wondering due to lack if trunk space if bass tubes are complete junk?
Also another reason for the louder highs is the all the extra horses I've added and the noise of the exhaust.
Quack, if I'm able to keep the 4 channel JL, I'm looking to spend 1-1,500
Mylows, Thanks. Looking into them now
#1 - sound deadener, sound deadener..this will not only lower the noise floor inside the vehicle and help with resonance issues, but it will reduce heat from the exhaust system as well.
http://www.caraudio.com/forums/murdermat-sound-solutions/554450-murdermat-introductory-pricing.html
#2 - possibly keep the JL 4ch. and look to components such as these for the front, keeping the rear ones you already have:
WoofersEtc.com - UP6 - DLS Ultimate 6.5" 2-Way Component System
Ultimate UP6i - 2-way component 6,5 inches
#3 - I have installed the bass tubes and they suck. Yeah, you get good output from little power, but the thing is a bitch to mount securely. I'd at least do 1 10" ported like one of these:
WoofersEtc.com - SA-10 D2 - Sundown Audio 10" Dual 2-Ohm SA Series Subwoofer
on a good compact class D like this for a solid 800-1000+w rms:
WoofersEtc.com - P1000.1 - Precision Power Monoblock 2000 Watts Max Class D Amplifier
PrecisionPower - Products - Amplifiers - Phantom - P1000.1
you did not say what JL amp you have, but I would look to 100 - 130w/ch, like this if it rated at lesser power:
Precision Power P900.4 Phantom 145 x 4 @ 4 Ohms Compact 4-channel Class D Amplifier 6.5x9.25x2
PASMAG | PERFORMANCE AUTO AND SOUND - Precision Power P900.4 Amplifier
The main reason I suggest these PPI amps are not only because they are good quality and underrated for the $, but they are very compact...imitated, but not quite duplicated...lol.
take the remainder and get a box built and equipment professionally installed (at least the comps and door treatments, if you question your own ability)along with the deadener in the trunk and anywhere else you can get it.. @pro\-rabbit; sells custom or flat packs on the boxes for pretty reasonable.
Alex81
Alex81
Houston, TX
quackhead
