Upgrading subs
  • 4
Yea that way u would only be taking up around 4" of height..very simple to make
Any good tuts off the top of your head you can link me to? //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I get my tnuts from lowes.i use 1/4" 20 ..if ur talking about the amp rack i just used carriage bolts and wing nuts on top for easy removal
That isn't bad.. Maybe looking at a i520.4 or i350.2 due to them being much smaller in size than the 800.4.. I can't decide
IONS does the same as black ice power wise but is a bit more efficient with the power. It just has minimal crossover controls hence the cheaper price but other then that its a real solid and clean amp with plenty of clean power.
I currently have 2 jl w3v3-4 10 inch subs. They have a rms rating of 500 watts and an Xmax of 14mm. I want more spl but only have the space for 10's. I am thinking of upgrading to 2 ssoundqubed 10 inch hdc subs. They each have an rms rating of 1500 watts and an Xmax of 36mm. My current setup only has around 150 watts to each sub. If I upgraded subs and amplifier, how much louder would these be?
how about you get an amp that would fully drive those subs first before you do anything else. Then get new subs later if your still not happy.
The Deaf bonce unit are not mdbass, they are midrange drivers. They will play pretty loud from 150 up. I don't support the company right now as...
359
Those NVX are very good indeed. I only have a leftover set because they were originally going into my brothers restomod 68 Chevelle SS and we...
624
Well, there is always a bypass that can be McGuyvered. So next time you want to tackle that task, post it. We can help.
Man, sounds great - no pun intended! Glad you're happy with those Morels, I think they are special. Not sure why they don't get the local love. I...
36
When I stripped my factory system and started from scratch. I didn't need any adapters. I wired the new head unit wiring harness to the vehicle...
939
Cbglasscock
Hoover,Al
Jeffdachef
    May 24, 2024
    May 23, 2024
