Upgrading from audiobahn to Image Dynamics
Mx3guy
Ok now i have 2 cheap audiobahn 10' subs hooked up to a soundstorm 850 watt amp on 2ohms.
2 audiobahn 10'
# 10" High Performance Subwoofer
# 45 OZ. Strontium Magnet
# 2" 4 Layer Black Aluminum Voice Coil
# 300W RMS Power Handling Per Sub
# 600W MAX Power Handling Per Sub
# 30Hz - 1kHz Freq. Response
# 91dB Efficiency
# Awesome Flame Design
# Bumped & Vented Polished T-Yoke
# Poly Coated 2 Layer Non Pressed Paper Cone
# Lug Lock Terminals
# Dual 4 Ohm Voice Coils Per Sub
# Rubber Gasket & Magnet Mesh Cover
* MonoBlock MOSFET Bridgeable Power Amplifier with Remote Subwoofer Level Control
* Max Power 2 Ohm: 850 Watts x 1
* RMS Power 4 Ohm: 200 Watts x 1
* Signal to Noise Ratio: 102dB
* Low Pass Crossover (Variable): 40Hz - 150Hz
* High Pass Crossover (Variable): 200Hz
* Bass Boost (Variable): 0 - +18dB
* Frequency Response (+/-3dB): 9Hz - 50kHz
* THD @ RMS Output: 0.01%
* Channel Separation : 90dB
* Damping Factor: 125+
* TriMode Operation
* Remote Subwoofer Level Control
* Line & Speaker Level Inputs
* Variable Input Level Control
* Dimensions: 11"W x 2-3/8"H x 10-1/8"L
For $424 I can get 2 ID12 v3 D2 hooked up to a Orion 600d
Subwoofer Specifications
* Size: 12 inch
* Rec. Sealed Box Dims: .8 - 1.5 cu.ft.
* Rec. Ported Box Dims: 1.5 - 2 cu.ft
* Free Air Usage: yes
* Sensitivity: 88.6 dB
* Frequency Response: 10-150 Hz
* Recommended RMS Power: 50-400W
* Peak Power Handling: 500W
* Impedance: dual 4 ohms subwoofer wiring options
Subwoofer Mono Amp Specifications
* Amplifier Type: Mono
* RMS Power @ 4 Ohms: 250W x 1 @ 4 Ohms
* THD at 4-Ohm RMS Power:
* Bridged RMS Power @ 4 Ohms: 400W x 1 @ 2 Ohms
* 1 Ohm stable - 600W RMS into 1 Ohm!
* Speaker Level Inputs: no
* Preamp Outputs : yes
* Built-In Crossovers: LP
* Bass Boost: 0-10 dB
* Frequency Response: 20-250 Hz
* Signal to Noise Ratio: 68 dB
* Fuse Rating: 50 amps
Is this worth it? I know its going to sound better but how much and is it worth the money im spending or is their a better way of doing it?
dont mix and match subs
bahns might get louder than those, what kind of box are they in, ID's arnt know for their loudness
My trio of ID12's, (See sig for pics) Wanged pretty good, hard to drink your soda on some oxy cotten action, loved that setup
The bahns are in a bandpass box but they are 10' and kind of sound bad at loud vol. when the beat moves around. The reason why I got them is because it was decent power for cheap.
Mx3guy
Mx3guy
Oklahoma
Mx3guy
