Upgrading amps and wiring
will6749
Hey,
So I just upgraded my subs, 2 12W7ae, and I plan on doing the amps soon.
I'm gonna get the HD1200/1 for the subs and the HD600/4 for my mids. If i run 1/0 from from the battery to a distibution block then 4awg to each amp is that going to be enough for those 2 amps?
I'm also gonna do the big 3 and either get a HO alt, or have mine rewound.
Also where is a good place to get fuse holders and fuses and distribution blocks? I figure I'm going to need at least a 200a fuse in the 1/0.
Right now its hooked up to a soundstream 1.1000d and its quite loud with the gain at half. that jl should be a lot cleaner, then down the road if i feel i want more i will just add a 2nd one and have 1 running each sub instead of 1 running both
ok, I'll probly hit you up for the blocks and fuses, but I'll most likely go with welding cable for the wire unless you can beat $2 a foot for 1/0. Also, would it be wise to have a length of 1/0 run back to the battery for a ground rather than grounding to the chassis?
depends on your car really ,if it's a unibody car then yes. also i sell the sky high wire for $2 per ft plus $6 shipping
will6749
will6749
Vancouver, WA
will6749
