Hi guys,
Thought that someone might be able to help me out here... I own an 07 accord Type S (no Premium Sound System). Keep in mind that I live in the EU (Ireland) so might be a bit different in terms of car designs etc but the story should be same in wirings etc...
Last week, I upgraded all of my speakers, got rear shelf, rear door (which had none), front door and tweets.
I also got separate 4 channel amp to power all those speakers for me and plugged that to the original head unit using two high level inputs converter.
So, I have the power wire running from the battery on the passanger side and the RCA + speaker cables running in the middle of the car.
I am getting a noise from all of my tweets when my level on the 1-2 and 3-4 channels are too high. I have set my gain level to around 20% and the noise stopped, whenever I bring up the level up the noise starts again and the higher I go with gain level, the louder the tweets make the noise.
Since I have my RCA's running on the other side than my 12v, I have grounded my high level inputs in the radio, I'm not sure what else might be causing this noise.
Anyone with similar setup who got a solution?
Thanks in advance!
Thanks in advance!
