Unhappy with box/setup. why?
What amp specifically are you using? Is your LPF and SSF set correctly? I remember when I first put in the XXX off 1500 my LPF was set to low and the higher frequencies wouldn't produce.
The SSF will also make a big difference. Don't just set it to it's highest level.
What amp specifically are you using? Is your LPF and SSF set correctly? I remember when I first put in the XXX off 1500 my LPF was set to low and the higher frequencies wouldn't produce.The SSF will also make a big difference. Don't just set it to it's highest level.
SSF = 1/4
LPF = 1/2
It's a saz1500
what's the xover set at?
I haven't installed crossovers .. are you referring to something else?
I want to but it's not recommended for the BL, duhh haha
try it anyways...... FS/QES 35.1/0.47=74.69
i always thought generally if it was 90 was suited well for ported
but i'm positive Fi knows their subs better than me and if they say no sealed, they are probably right
Hmmm....idk well some ppl have different taste in tunning...perhaps tunning higher would help...I really dont know the specs on ur sub and its performance...but maybe tunning a little higher would help you.
Kastlez_
Kastlez_
Bay Area, CA
FredS3251
