Under $150....
RE Comps... where can I buy them/look at their specs and what not? I've looked into Infinity Kappa 60.7cs but I don't know how much power I need to give them and at what impedance...
Ok since you two recommend Dayton products, would this setup be a good sounding system for the money?: 2 Dayton 7" reference woofers, 2 neodymium 3/4" tweeters, and 2 4500k 12dB slope crossovers... since the woofers are 60WRMS a piece and the tweeters are 15WRMS a piece I would need an amp that powers something along the lines of 75WRMS x 2 @ x ohms right? Right now I'm not sure how I'm going to get 4 or 2 ohms per side, but I'll figure it out... I'll probably need either 2 8-ohm speakers or 2 4-ohm speakers per side, correct? Also would a setup like that perform as well as the RE comps or better or worse?
No.
4.5khz @ 12db/oct is way too high for those mids.
Honestly, unless you are going active I'd just buy a prebuilt component set. Any of those generic passive xovers are really going to negate any benefit of going DIY. Generic passives simply won't do the speaker justice at all.
OZ Audio Vector series can be had from Tplaya07 for less than $150 shipped.
DLS has some component sets in your price range: http://www.mobilesq.com/store/index.php?cPath=27_50_51_60
You can find the Memphis Msync 6.5's for close to your price range if you look online.
Crystal SSCS are very close to your price range aswell: http://www.infinitecaraudio.com/cgi-bin/icastore.cgi?user_action=detail&catalogno=SSCS6
Contact 6spdcoupe...Rainbow may have something in your price range aswell.
Ok, I've contacted tplaya07 with no reply yet; 6spdcoupe is searching; I've tried contacting RE and their components are on backorder, but I was wondering what their power handling is?
96civ
96civ
Indianapolis, IN
Randy Savage
