Ummm. Amp Question Pleaseee
JHardee
Cadillac
so i have a 4gau. wiring kit running from my battery to my trunk and at the moment i have a little 2 channel amp running my components up front...
i plan on just unhookin the MA amp and hookin up my ed.nine1 for my sub but then how do i also hook up the MA amp for my speakers? like do i need to buy a new kit and run it through my car in the back so i can use MA amp? or.. is there like splitters.. for like remote and rcas and whatnot....
thanks
If your hu has an additional set of rca outs, you'll run another set of rcas to the other amp. If you dont have extra hu rca outs, use y adapters or amp passthru if supported by the amps. For the remote just daisy chain it off existing amp.
For power, like dafob said use a distribution block but you may want to think about running 0/1 ga from battery back depending on your amp draws, and then use the block to run 4 ga to both amps.
i have a dist block. but im wondering. if i should upgrade my wires.
because my first amp. initially has 4 awg. but when i got my frontsage amp installed. they only used 8 awg. so should i upgrade my ground and power wire to all 4 awg?
JHardee
Cadillac
JHardee
772 Florida
dafobbishon3
