uhh wtf is happening?
NJTStang11
Ok, so I got back to school this week, and after the long ride back, my subs have been acting funny as hell. I start up my car, and my subs make a weird noise (bass, quick moving, low tone). In between songs, same thing, when I shut off my car, same thing. They are constantly making noise when the amp is turned on and it all started after the car ride. Any ideas of what to check out first? Subs also sound a little off on their beats and less accurate.
I had this problem and it was with the RCA's..... on mine the RCA inlets on the amp were loose inside the case. I took it appart and JB welded them and the problem went away. Try going back there and wiggling it around while that noise is going on.
when you put down your window or push your lock button does it do it because if so then one of your wires you put through the firewall is getting interference and needs to be moved away from other wires or it could be the rca getting interference behind the dash
why not contact me? theres a bunch of things it could be:crap:
NJTStang11
NJTStang11
Chicago, IL
NJTStang11
michigan born
    May 14, 2026
michigan born
    May 14, 2026
