uhh What does this do "passive radiator"
its passive because you can pass by it and think its a subwoofer... the radiator part is because what their purpose is it to cool your subs and when your sub start beating the "passive radiator" acts as a real radiator and cools your sub....its a scientific breakthrough pretty much
I hope you aren't serious?
Anywho, a passive radiator is similar to a subwoofer except it has no motor structure, just the suspension, cone, basket, blah blah. It works similarly to a subwoofer except it receives no electrical signal of any sorts, but it uses the pressure that the subwoofer creates inside the box to resonate, a lot of companies will add mass to the structure to change the characteristics of the PR.
It's very similar to a port, but you can save space because the PR will usually be tuned to a specific resonant frequency and thus your box will comparatively be smaller, and give you similar output.
its a speaker without a motor..
it is used with another speaker
When the sub woofer moves.. it causes the passive radiator to move with it which causes an increase in db's
it worthless by itself unless paired with another sub in the same box.
lol extreme joke..not even close to being serious
lol ok, it's occasionally hard to pick up on sarcasm while reading text //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Where in tampa are you? I'm about 45 mins north of you in New Port Richey.
Before the advent of all the cool programs that calc PRs, I used to approximate a PR design by using the SD of the cone and equating that to a cylindrical port. Given the box size, tuning, and the PR sqin you can calculate the length of the "port" (often obscene given the SD of a 12" PR going into a 1.5 cuft enclosure). From this port length and port area you can calculate the volume of air and therefore the mass of the air in the port. That mass is the theoretical mass your PR will need to tune the box to the frequency you have calculated... I say theoretical as you are assuming that the suspension of the PR is close to that of air (ultra floppy) when in reality it isnt. The floppier the PR, the closer this comes out right. To tweak just add mass.
But since we no longer communicate via smoke signals or the pony express, you simply plug in a couple of things into a program to get the same results... along with the graph and excursion levels of the PR at given frequencies and power.
Normally you use twice the volumetric displacement for the PR as for the driver itself. (2)12" PRs per 12" sub (with similar excursion levels) or usually you can get away with kicking the PR up to the next size (15" PR for a 12" sub).
PRs work great for home... and somewhat well for car applications, although the PRs need to be mounted horizontally (to the axis of movement) as they will sag heavily due to the moving mass and lack of suspension.
Thanks...
Scott
Thanks...
Scott
You're welcome.
Guess it works great for me since my home is my car. Yay.
south tampa...yea i know where you are ive driven to NPR a couple times
PendulousThread
PendulousThread
Detroit
Railrocker
Mike Mccabe
