Two subs, two boxes, one channel?
Ali G
Soundcrafter
I am planning on getting two 19Ov.2s when they come out, but to fit them in my trunk, I will need to build to seperate boxes to be able to squeeze them through the opening.
My question is, will it be fine to run a mono amp to both speakers even though they are in seperate chambers, or will it create some bad cancellation or loss of SQ? Should I look into getting a solid two channel amp or will my plans of running a NINe.1 on them work out?
Thanks,
Justin
subs are always in separate chambers. You'll see little to no difference whatsoever in using 2 separate boxes as opposed to 1 enclosure with 2 separate chambers.
You'll be fine running a mono amp.
Ali G
Soundcrafter
Ali G
The D
Ali G
BP1Fanatic
BP1Fanatic
