Trepkos
Is there any pros and cons to doing this and would it be better or worse then two chambers?
x2.The con only rears its head if you routinely blow stufff up. If you don't abuse your equipment, there's no con.
Phase does not come into play unless the drivers are wired incorrectly. If the subs are wired to different channels, a difference in power or crossover point/slope is a possibility. The separate channels are identical in construction, so time delay isn't a concern.Don't they also have a better chance of phase issues in one chamber?
