Two D9's @ .5ohm strap'd
My single D9 doesn't like much under .5ohms (shuts off, although it does depend on application) so I don't know how well a pair would work strapped at .5
I imagine the draw would be around 1200+amps with a pair strapped that low.
My single D9 doesn't like much under .5ohms (shuts off, although it does depend on application) so I don't know how well a pair would work strapped at .5I imagine the draw would be around 1200+amps with a pair strapped that low.
is that .5 before, or after imp rise?
i run mine at .35 daily before rise and never shuts off or gets warm.
I meant below.5 starting load. I tried it on a quad 1ohm 15 at .25 and it worked great, but I tried it on 4 d2's at .25 and it would protect easy, also protects easy on 5 d4's at .4
Its fine up until 2 or 3 clicks from full volume, so works great for daily, but not at all for competition. I did try volume roll (fast and slow) also and it still does it.
I meant below.5 starting load. I tried it on a quad 1ohm 15 at .25 and it worked great, but I tried it on 4 d2's at .25 and it would protect easy, also protects easy on 5 d4's at .4Its fine up until 2 or 3 clicks from full volume, so works great for daily, but not at all for competition. I did try volume roll (fast and slow) also and it still does it.
wut kind of electrical u back urs with ?
Stock alt, 2 good batteries (group 34 under hood,1 group 65 about 6 inches from amp), big 3 (1/0ga everywhere). It's not a ton of electrical, but the voltage wasn't that bad. I'll be replacing my alt with a Mechman Rhino 250amp and I'll try again after I do that, see if it makes the difference.
My box rise isn't that much, so that could be a difference also. In the one application where it did work, I didn't have a chance to clamp actual power, but it definitely was a beast!
try keeping your input signal to 3v total. if you use two RCAs 1.5ish each.
Well I definitely have more input voltage than that...are you suggesting to lower the input voltage and raise the gain on the amp? I assume thats what you mean, because otherwise I can't get full output.
Stock alt, 2 good batteries (group 34 under hood,1 group 65 about 6 inches from amp), big 3 (1/0ga everywhere). It's not a ton of electrical, but the voltage wasn't that bad. I'll be replacing my alt with a Mechman Rhino 250amp and I'll try again after I do that, see if it makes the difference.My box rise isn't that much, so that could be a difference also. In the one application where it did work, I didn't have a chance to clamp actual power, but it definitely was a beast!
I dont think you have enough battery , especialy on stock alt
Savag3
sav'd out
Savag3
Central KillaCali
Savag3
vegang
vegang
