Two Amp Help
99durango5.9L
NY
....im sure i need a distribution block....im not quite sure what i do with the remote wire tho...split it?....also they are two of the same amp....but how would i wire the bass knobs?....i don't want two up front, or is that what people do?....its a total of 2400w rms.....what else do you think i would need....i have a 136 amp alt stock....and a yellow top....i just have to 1/3 of the three done....
split the remote.....
on the big three my alt positive goes to my fuse box....then from the fuse box to the batt....i would obviously upgrade both wires....but i don't need to put on another fuse do i?.....
not too sure, but i think he has 2 sub amps that are the same. if so are you strapping them? if so i think you would only need one knob.
i am not certain
the two amps are to two subs...1 amp per sub....can you some how connect the two bass knob wires together?....
i dunno. i dont run a remote gain knob. does it look like a phone cord?
yeah pretty much....without the curls....//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif....
you go from the battery to the alt. fck the stock fuse box. it's optional to put in a fuse on this wire. people do some don't . i did not
so i can just run the alt straight to the positive on the battery.....i don't have to go though the fuse box //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
99durango5.9L
99durango5.9L
NY
99durango5.9L
Mike Mccabe
