two 10s or one?
  • 2
No two channels have the exact same output. They all have slight electrical differences between the channels.
Can you do it? Yes. Would I? No.
What amp and subwoofers?
You are going to laugh at my amp its a crunch pz-2020.2 1000w @ 2ohm x2 I'm thinking it's probably around 250-300 rms x2 @2ohm
Your first post you said two dual 4 ohm subwoofers and later said you currently have two single 4 ohm subwoofers.
Amp is only stable to 4 ohms bridged. So two single 4 ohms would be at 2 ohms.
If you have two dual 4 ohms you could either run them both bridged at 4 ohms or one per channel at 2 ohms each.
Yes but each individual channel is 2ohm stable so 500w @4ohm, x2 1000w x2,@2ohm or 2000w @ 4ohm bridge
I'm thinking about getting some new subs that's why . How much more boom will i get running some new dual coil 10s?
As long as the subs are close to each other and the signal to is not Inverted on any subs, cancellation is not a big issue with sealed enclosures...
23
Good explanation, thanks. I'll try installing that other amp soon. I have a stinger cap that shows my volts. It's reading 15v at max volume with...
17
You can raise the back sea approx 2 inches and get a front firing enclosure for two tens in there ported center. Other than that. Atrend makes a...
Coreybruner
CarAudio.com Recruit
Coreybruner
Sacramento
Coreybruner
SlugButter
    May 4, 2024
slater
    May 2, 2024
