tweeters and woofers at same gain level?
sjv13
StayStrange
So I have the Focal IS 165 component speakers. And I have a 4 channel amp that's 75x4. I have each part of the component set on one channel.
Left tweeter, channel 1
Right tweeter, channel 2
Left woofer, channel 3
Right woofer, channel 4
There is one gain control for channel 1 & 2, and one gain control for channel 3 & 4. My understanding is that tweeters take a lot less power than woofers. So why is it that both gains are turned up almost the same amount and it sounds good to me? The woofer gain is up just a tad more than the tweeters.
do you have the xovers set ,hp for the tweets and bp for the mids ,also you should do a electronic xover as well.it will highten the response for the components and give you better adjustment over the amps settings
The Focal IS 165 comps have integrated xovers, so there is no crossover box. So really all I have to set is the HPF for the woofers, which is at 90.
thats because your mids aren't supposed to play frequencies that low .more adjusting is needed .also your mids may not take the power your pushing to them ,it does say 70 watts rms for these
I know that lol. That's why I use the hpf on them. I'm not pushing them all the way... the gain is quite low.
---------- Post added at 09:17 PM ---------- Previous post was at 09:16 PM ----------
What impedience is the tweeters? Subs probably a lower impedience so seeing more power.
You mean woofers?
And yeah, that might be.
I have been running my Hybrid Audio Imagine tweeters and woofers in bi-amp mode, and also with active crossover. In both cases tweeter gain position was pretty close to woofer gain in order to level match the tweeters and woofers (this is on a channel with 80watt RMS rating). What's going on? Take a look at the frequency spectrum or normal speech or most music in any music player software. I used foobar2000. For just some random pop/rock song in my collection.. Peaks in bass region reach -10dB, peaks in midrange reach -20dB. Peaks in upper midrange -35ish dB. Treble (>5KHz) normally at -40dB. So the point is, if I was playing 0dB tones on my stereo, this would probably destroy my tweeters. For normal music, this is not an issue.
If you have the ability to mute woofers and subwoofers, do this as an experiment. My tweeters use 6.3KHz HP with 18dB slope. After muting the woofers and subwoofers, it's surprising to hear how little content in SPL terms the tweeters are contributing, and yet music will sound lifeless without it.
I have been running my Hybrid Audio Imagine tweeters and woofers in bi-amp mode, and also with active crossover. In both cases tweeter gain position was pretty close to woofer gain in order to level match the tweeters and woofers (this is on a channel with 80watt RMS rating). .
I believe the Imagine tweets are 12 ohms, which would mean that they get 1/3 the power of the mids with the same applied voltage. It makes sense that a tweeter with no level controls in the crossover would want the same signal level as the mating midrange.
sjv13
StayStrange
sjv13
Lansing, MI
maylar
Mike Mccabe
