Tweeter question because i dont get it
And that doesn't seem like a problem to you?
You can easily still clip an amp with the gain set at less than half, don't open your mouth if you don't know what your talking about //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Ok. Obviously I was less than clear with that one. I understand that you can clip an amp at less than half gain. I was more talking about for the sake of the amp. Not everybody has an o-scope at their immediate disposal.
How comes I never blew a mid? why the tweet goes first? Plus I thought since im using the passive crossover that the signal is distributed accordingly
Sorry, I meant to bold part of that quote, I was focusing on the fact that your amp gets hot. That's a red flag that something is wrong. It might get warm but it should really never get hot.
Could the amp not be good?
You're less likely to blow your tweeters if they have their own channel of amplification. This can be facilitated either by using passive crossovers that can be bi-amplified, or by using the active filters in your head unit or amplifier, whichever the case may be.
I dont think this amp is good at going active. The HU i dont think can go active.
I kinda rule out going active because i dont have enough knowledge to do so safely. so thats why i decided im going to use the passive crossover where i set it and forget it.
That's okay if you're more comfortable using passive filters, but not all of them can be bi-amplified. Hopefully yours can be, then you just need four channels of amplification - two for the mids, two for the tweets.
These articles may fill in some of the blanks for you concerning your history of blown tweeters. It'll take a little while to read but I guarantee you will learn something.
Why Do Tweeters Blow When Amplifiers Distort?
BiAmp (Bi-Amplification - Not Quite Magic, But Close) - Part 1
Thanks for the links. im going to read them.
These crossover cannot be bi-amped. they are the crossover from the XS65 set. also the tweets are from that set. Image Dynamics.
No. That is most likely not the case. The amps temp fluctuation could be because of many things; impedance, insufficient power/ground, gains, etc...
The amp I use for the sub do not get hot. its a JBL 600.1. I had this JBL amo for about 4-5 years now and it never gets that hot.
This may seem counter-intuitive, but another option is to use an amplifier with more power on reserve to keep from clipping the tops off of high frequency waveforms. That will make more sense to you after you read those two articles. Mind you, the extra power is not so you can throw more continuous power at your components, it's so you will have clean reserve power. With more power on tap you will be tempted turn it up more, and you can to a small degree, depending on how much power you currently use, but if you're not careful you run the risk of repeating the cycle or simply cooking the coils with too much continuous power.
Also, try not to boost high frequencies too much, if at all. Rather, cut your midrange frequencies if possible, to provide the same relative frequency response that you would have by boosting the high frequencies. This will somewhat help keep more reserve power in your amplifier. Everything in moderation.
That makes no sense...Clipping can destroy speakers AND amplifiers.
Yes, I know. I was simply pointing out that if he was worried about the excessive heat coming off his amp, he could dial back the gain. He set the gain by ear, so is it not possible that he could be pushing the amp too hard?
Where are the tweeters mounted? If the drivers side is extremely off axis vs. the passengers side being on axis, it's level will be considerably down from the right tweeter dependng on the tweeters themselves. Sure your not doing some adjusting to compensate for this? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Its very possible there is still clipping going on. Just because you dont hear distortion doesnt mean its not there.
ID passive crossover. ID tweeter. Rainbow mid. MB Quart 4125 amp. PLus that amp gets hotter than hot sand.
Hell yea it does, but thats b/c you have a very low resistance. Probably going below recommended ohms. Heat from the amp will cause the speakers to over heat and inevitable blow. The way to fix this is to get another MB Quart 4125 or a better amp in general...or just turn down the amp gains. But then you wont hear shit.
Theride
Theride
NY
Villeza1
