Tweeter Crossovers are they needed?
Morts
OK I am a little confused here. I have always used tweeter crossovers even after an active crossover. I just got a new set of tweeters and they are 6.4 ohm and have no crossovers with them. I have an old HiFonics amp with 2 crossovers built in the amp, one for low/mid and the other for mid/high 75-5 kHz adjustable. Do I need tweeter crossovers? What would be a good crossover point to set at so I dont fry the tweeters? Sorry for the question but I always used the crossovers. The tweeters frequency response is 1500 to 25000. So would 2K be safe? Thanks
The active crossover on the amplifier will be 12db/octave (more than likely). I'm guessing (obviously only guessing) you were using a 6db cap only for the tweeter as a passive unit too?
Are you going to be running the tweeter in conjunction with a mid-driver on the same channel? If not, then just run with the active crossover on the amp. At 6.4 ohms, you will have a lower output than a 4 ohms unit. Depending on the efficiency of the tweeter it may not be a big deal.
The crossover will keep the coil on the tweeter from moving too much and "jumping the gap" or tearing it apart thus destroying it. I would keep the tweeter crossover around 3.5K - 4.5K.
It is indeed a 12dB/octave x-over. The tweeters are run separate on 2 of thier own channels 1 and 2, my mids are on channels 3-4 and the sub is bridged on channels 5-6. So I will not need any passive crossovers and if I set the crossover at 3.5K I am safe? I never ran a tweeter without a crossover and wanted to make sure I didnt fry them without a passive crossover or blocker. Do you think 2K would be too much with them on separate channels? I appreciate your reply and your time much is appreciated.
I have not got these tweeters yet they are in the process of being shipped to me. I am not going to run a passive crossover at all with them. Just need a safe crossover point for them I guess and want to play them as low as I can and be safe. Hope I cleared it up now and I appreciate the input guys.
Morts
Morts
Buffalo,NY
Morts
vegang
vegang
