turning up the HU volume.....
Is it linear? How does it exactly work?
For example' date=' let's say you tune your subs to 30/50 on your HU. Your amp can do 300wrms at 30/50. Does this mean that at 15/50 you'd be doing 150wrms?[/quote']
no clue, way to find out would be to check rca output voltage at each volume notch
There's an easy way to figure it out using an SPL meter. You're supposed to get a doubling of power at every 3db rise in volume. Could just use a DMM and SPL meter to graph it out.
I have a feeling that on the lower end of the HU volume control, the clicks needed are greater than the higher end due to the logarithmic nature of wattage/decibels.
Could this mean that in reality, 150wrms could be in the high 20's?
A volume control is (or should be) logarithmic because of the way the human ear perceives changes in SPL. At low volume we hear small changes, but the louder it gets the more change is needed for us to hear a difference.
So to answer your question, 1/2 volume is way less than 1/2 power, and without knowing the HU implementation of the volume curve you can't really predict it.
Beatin'
Beatin'
MI
maylar
michigan born
    May 14, 2026
michigan born
    May 14, 2026
