turning sealed into ported
Beatin'
I know it's possible, but is it worth it?
I have a dual sealed box for 2 15's. There is no room in the front to have either a round or slot port. Not to mention it also has a center divider....
I could put the ports on the sides, but would that affect output? Would there be some degree of cancellation or any other ill effects?
leave it sealed, and build a ported box. it doesn't work like that.
first of all most 15s need at least 3 cubes.
you probably wont have enough space for port length unless you tune in the 40s.
Most likely not going to work. Your subs need more airspace to be ported than sealed, plus you need to factor in port length or you won't have any tuning. Best to stay sealed or have a separate box built to go ported.
I wonder.......since space is an issue with port length' date=' can you have the ports sticking out of the box?[/quote']
You can, but it's internal volume that should be your concern. You won't have enough in that sealed enclosure.
Ultimately, I will build a couple of proper ported boxes for each 15, to better fit them in the trunk.
But for experimental purposes, I think I want to turn my sealed box into a ported one. //content.invisioncic.com/y282845/emoticons/silly.gif.3549b64aaa5b6729eb8e865319a3234f.gif
Can anybody predict the outcome? What is typically the shape of the frequency response with such a small internal volume?
Ultimately' date=' I will build a couple of proper ported boxes for each 15, to better fit them in the trunk.
Can anybody predict the outcome? What is typically the shape of the frequency response with such a small internal volume?[/quote']
Outcome is you could inadvertently cause damage to your subs with the extra excursion caused by being able to go ported without the added benefit of good excursion along with a lot of extra shtuff in your trunk. Not worth it, but if you feel like experimenting, go ahead. Personally, I'd rather hold onto the sealed box if I wanted a change once I went ported.
let me save you some trouble. i was 16 once. i ruined a good sealed box too. dont do it all your low notes will disappear and you wont gain any output
I think my time will be better spent just going ahead and building a couple of ported boxes from the ground up.
thanks for the input.
Beatin'
Beatin'
MI
ThatChevyGuy
