Turn on lead?
TheOol
When I turn on my car, sometimes my amp won't power on. It turns on when I turn the hu off and then back on. Could this be a problem with the turn on lead or amp? thanks for the help.
(this is just adds to the reasons i hate audio express...)
Originally posted by 82bronco yes one end goes to the h/u and the other to the amp but if u dont wanna have to rewire the amp just hook the end that would go to the h/u to the power on the amp
no dude DONT do that
doing that would cause your amp to be on all the time...and it will kill your battery
your car wont be able to start
get your amp checked
the lead could be shorting out
Originally posted by 82bronco oh yeah i for got about that dont do that:)
yupp DONT
//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
what you CAN do is look for another 12v source in your car and run it to the remote lead for the amp....to be safe put an in line switch
try that
if it still doesnt work...then something's wrong with your lead
you should be able to hook it up to the car ignition system most car have empty ports for accessories. and some decks have many different remote wires so make sure that the are all hooked up to the right connection , and check the led for grounding out. that can fry the deck remote out
Well, since this has been happening, I have a new development - my amp has decided to stop working completely. It is really pissing me off. Tomorrow will be devoted to trying to fix this problem, and audio express will get another earful and hopefully they won't be sick enough of me to help. Thanks for all suggestions, even though I never got to use any of them.
Originally posted by A-hole you should be able to hook it up to the car ignition system most car have empty ports for accessories. and some decks have many different remote wires so make sure that the are all hooked up to the right connection , and check the led for grounding out. that can fry the deck remote out
Well hey there a-hole, looks like we actually have another phoenician. I thought I was mainly talking to Canadians on this board lol. where in phoenix do you live?
TheOol
TheOol
Phoenix, AZ
TheOol
