Tuning Question
Burbanhunter
This is kind of how I want my box we will be adding some surprised but this is the basics of it.
Ok for the car audio techs. What is the specs to make this port tuned at 30hz-35hz
L ( ) W ( ) H ( )
I know my installer will know, but I just want to find out for myself. Oh yeah could you also let me know how you got your answer I want to learn as I go.
thats a pretty big box you got there you must be goin with 18's....but with a port 32" wide (or long) and 12" high at 20" deep that will give you nearly 15sq" of port area/ per cube... at a 33hz tuning....and this box will be around 26cubes after port displacement...hope this helps
What thickness MDF are you going with? Are you going to double up all around, double up just the baffle...what's the displacement of your subs? How much space is your internal bracing taking up? What kind of setup are you looking at doing with that box?
If you use 1" MDF all around you'll have 28.6ft^3 to work with before any displacements, if doing 3/4" all around you have about 30ft^3, and a little under 29ft^3 with a double 3/4" baffle. Double 3/4" all around and you're down to 26.2ft^3 before displacement.
Burbanhunter
Burbanhunter
America
RAM_Designs
