So I got a new 2016 Focus ST and am planning out the install. I've done quite a few installs over time so I am not a complete newbie. They have always been fairly straight forward with passive crossovers and measured time alignment. However, for my next install, I would like to try going active and get into a little more in-depth tuning. I have read a lot about time alignment and EQing and will continue to read before the install but I wanted to double check the tuning order.
Likely equipment:
Pioneer DEH-80PRS
Morel Tempo Ultra 602s
US Acoustics Barbara Ann
IDMAX 12 (I think the box is 2.4cu ft ported @ 32hz)
Audioque 1200D
Below is kind of what I have come up with in generic steps. Obviously some of these steps will actually be many steps and repeated. Does this order seem OK?
Set amp gains for mids/sub
Temporarily set HPF crossover on tweeters only (2.4kHz, 18dB)
Set tweeter amp gain to match mids by ear or RTA
Time align with pink/white noise
Center more with tones matching 80PRS EQ points (turn down L/R depending on off center)
Measure frequency/SPL with RTA per speaker with pink/white noise
Set all 'final' crossover points
Tune EQ to desired curve
Likely equipment:
Pioneer DEH-80PRS
Audioque 1200D
