Tuning guess
dr00mx
Alright just want to find out if this box is worth getting until one is built.
Dimensions
Box
Width - 28in
Height -13 1/4in
Depth- 13 1/8in
Port
Width - 3in
Height - 13 1/4in
Depth- 16 3/8in
Sub displacement - 0.09cu.ft.
Can any one tell me what its tuned to? I'm sure it's going to be up there.
Any good since it has a port on the side?
Thank you.
Dan K.
I just plugged in a few numbers and it seems like your box is a little around 2.3 after port displacement...and with those port dimensions, I get right around 45ish hz. I could be wrong tho I'm kind of new at figuring boxes out. But if it is tuned to 45hz then I wouldnt want it for daily use.
You can play test tones or a sweep to give you an idea of where it is by watching how cone excursion varies with frequency. there'll be a dip in cone excursion somewhere (at the tuning frequency)
Yea I forgot to figure in the wood thickness also so your box is probably smaller, which makes the tuning higher. Ha, best bet would be to play tones like he said ^
That's inside measurements no need for wood thinness.
I'm thinking 45-50Hz.
I'm sure that be pretty loud but sq ****.
The recommended is 2.1 45Hz ported going for spl.
What do you guys think?
That's inside measurements no need for wood thinness.I'm thinking 45-50Hz.
SQ is going to suffer, but all you can do it try it, and maybe you will like it?Alot of prefabs are around 40 so yea //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif Good luck
Um, I know a guy named Trevor does, not sure what hes name is on here tho something like thumpper...hes from canada and made my first one, but if I were you I wouldnt want to have to pay for shipping all the way from there. I'd just make a thread asking if someone will make you a box tho. I'm making my first box at the moment and I really have no clue what I'm doing but its going well so far //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I'll probably just use this box and I'll try to build one myself.
Have all the tools so it shouldn't be a problem.
good idea bro //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I'll probably just use this box and I'll try to build one myself.Have all the tools so it shouldn't be a problem.
Yea that sounds like a plan...it really isnt that hard at all. The main problem for me was just trying to figure out the tuning for the port, but this site helps with that. http://www.the12volt.com/caraudio/boxcalcs.asp Hope I helped a little atleast ha.
dr00mx
dr00mx
Mokena, IL
Cabin_Pressure
