Tuning Amplifier - Any Watts Available?
Astyl
Car Audio Enthusiast
Hey guys... so using your tuning method
wattsxohm=sqrt= final voltage number
it seems to me like a infinate number of tuning is possible?
Like say you have a 2500 watt amp, but you wanna tune it to 1600 watts? just plug in xx volts on the gains... got a 1000 watt amp? wanna run 400 watts? plug in xx volts on the gains
Why dont people do this? They always try to match amp with sub.. well if this is the way that everyone does it, you can match ANY amp with ANY sub, just plug in the right number of volts and your good to go , no matter what the amp is rated
Say you have a 40 watt rated amp
and you wanna run 40 watts @ 4 ohm
40x4=160sqrt=12.6 volts
so you tune your amp to 12.6 volts, boom your at 40 watts
but say you wanna only run 20 watts out of your 40 watt amp?
20x4=80sqrt=8.9 volts to tune to put out 20 watts rms
think of this, but on a larger scale with subwoofer amps
see what i mean now?
Is it possible?
Basically i have a subwoofer thats good to be run at 1600 watts... but my amp is a 2000 watt amp, can i tune it down to 1600 watts and call it a day and be perfectly fine? if anything it should benefit both the sub and amp, reducing clipping potential dramatically and stress
what are you talking about?
i just wanted a simple yes / no answer to my above post after yours lol
i know how to set the gains, im just asking if i can set them lower then rated so it'll work
for a TCAB - 15 Inch Type R setup, i dont want to take any chances...
1600 watts daily seems rational to me.. i dont want to crank my amp to full power and run 2K watts to it on a daily / full boomin volume basis and hope that it'll be fine
If you read that link it gives you your answer, it is not a gain setting tutorial.
But im out of this thread. now.
Is it possible?
Yes, people have been doing this for decades.
Really, with music you'll likely never see anywhere close to 2kw out of the amp....but to answer your question yes, you can limit the power output of the amplifier. Heck, that's what the volume knob does. Many, many people use larger than necessary amplifiers and use only a portion of the amp's available power output.
Why don't more people do it? Because most people don't want to pay for more power than they're going to use
You can do that.
Lots of people may buy a higher output amp than what their current subs may be able to handle. Then at a later date when they can afford better subs, they have the amp to drive them. But in the mean time, the can lower the gains using the subs ratings to keep from blowing them.
*edit* In Theory
Astyl
Astyl
Bedford, NH
Rattlebrain
