tuning amp?
spaz0055
i have 2 12" type r's each with their own mrd-m605 amp and i was wonderin wut to set the controls at (gain, subsonic filter, variable cross-over). the gain on the mrd-m605 is different cause it is digital and adjusts from 0.5 volts to 8 volts. i hope i made sense is sayin all this, if u dont get somethin just tell me and i'll try to explain it again.
they r in seperate sealed enclosures, i built my own box. they r dvc but i have them wired like its one. also the amp only adjusts the gain in like .1 volt increments and thats it, its nothin like the tutorial posted, just from .5-8 volts. it is at .5 volts right now cause i havent adjusted it yet, by making it higer would it make the subs louder?
lets start over, i have the subs wired to a 2 ohm load in a sealed enclosure. on the amp there is a crossover freq adjustment knob, LP slope switch, subsonic mode selector, the gain, and bass EQ. wut should i have these at
I am guessing you have each sub wired to 2 ohm. Check out http://www.rockfordfosgate.com and go to the woofer wiring wizard under the support tab to make sure they are wired correctly. Don;t worry about the subsonic filter because they are in sealed boxes. Take a DMM and without the subs connected put the pins on the speaker terminals and adjust the gain until you get a readout of 34.64 V. Put the cover on the amps and you will be good to go.
so all i need to do is disconnect the subs at the amp and put the ends of the dmm in the amp and adjust the gain until i get a read out of 34.64volts? do i need to adjust the volume, i know i need to turn off the bass eq, treble, etc.
spaz0055
spaz0055
Cumming, GA
spaz0055
