tuned boxes??
They're talking about the tuning frequency of a ported box. The size of the box and port effect the tuning frequency, a lower tuning around (40) will result in a louder setup. If you play a note to a sub in a ported box that is below tuning frequency, it's like the sub isn't in a box at all, so people use subsonic filters to filter out those notes.
Be aware that a box tuned to 45hz will be louder at 45hz but will not play well or loud very far below that 45hz. So if you want a box that is very loud at a low freq like 30 hz then tune it to 30hz. Most ported set-ups get loud it just depends on whether you want a wide range of freq. to get loud or a smaller range.
It has to do with port length/diameter/box size. For a given box size the longer the port ie pvc pipe etc the lower the tuning. If you had a 3 inch diameter port that is 12 inches long in a 1 cubic ft box it would be tuned to 36 0r 37 hz, to get that same box tuned to 26 hz it would have to be 26 inches long. The longer the port the lowet the tuning, but if the port is 4 inches in diameter then it would have to be even longer. I've attached a page that has a port length calculator and box dimensions etc. Play with it and do some searching on the web.
http://www.the12volt.com/caraudio/boxcalcs.asp#par
This is a great question, I thought that the Freq response is realtively flat from tuning of lets say 30hz on up. Would a 30hz tone be louder than a 40hz tone if the box was tuned to 30hz? All things being equal.
sound giant
sound giant
Aiea, Oahu, Hawaii
DFW40
