Trying to find crossover specs for older Focal Crossovers....help
  • 1
PeerlessAudio
Does anyone know the crossover points on an older model Focal Polyglass 3 way crossover (FAV2)??
I've had these crossovers for at least 4 or 5 years, and I'm debating purchasing another crossover with known points that work with the setup I'll be purchasing soon. If the points on these old Focals are within +/-100hz across the board I will keep them. Anyone have any ideas?? I've checked online and can't find any info, so I was hoping someone on here had a set of these or a manual. Thanks.
389
i would not worry about the tweeters. They will never see anything above 20 watts before your ears bleed. your options with 4 channels would be...
751
Just need to find id to get a users Manuel thanks
Yep.3012r and 33.never drop below 14.1.have the jp84 as well.solid electrical.
17
4K
PeerlessAudio
PeerlessAudio
Charlotte NC
PeerlessAudio
