fyi the kx2500 is basically 2 kx1200s you are still in the same boat, its a no go. If you wire each sub to an amp... you can wire at 2 and 8 ohms. If ya wire two subs to one amp, then you can wire them to 1 or 4 ohms.... Just get the orion. No new kicker amp will do what you need with these subs.well i just looked the specs for the kx 2500.1 and it does 2500.1 @ 2ohm's! i found the amp with the power and ohms god i love kicker
thats why i always put mine between the seats //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifwhat year of s 10? in mine i had 10" at the bottom but not all the way across and you have to account for the WHOLE woofer not just its depth plus room for the cone to move. to safe another 3/4" i would build it into the truck (where the back of the cabin is the back of the box) in mine including a fishman grill it is 9 and 3/4 or so total deep and that is 1 notch away from the seat all the way forward
