Truck install pics.
koolwhipman
Busy busy busy...
Well, heres what I have been up to. This is in a 95 GMC fullsize regular cab. Tuning it is near-imposible. I hate going from 0-60 with all gear being replaced at once. Fronts/rears/subs/amps. What a pain. Anyway- PICS!!!
I was originally planning to have an amp on each end, but decided part way through to have both together to simplify wiring.
Initial layout.
Spacers.
Beyond flush mounting.
Internal.
Screwed and glued.
Long way from end to end. Sixty two inches. The tape was to hold a small peice of wood in my angled corner while the glue dried.
Internal.
Layed out for a test fit. Carpeted tan and inset is painted same green as truck. Very vehicle specific.
A few handfulls of stuffin. Also some stuffed between subs.
Only ten pics per post!
Here is whats in thur. Also 6.5 eclipse 3-ways in front doors. Didn't have a box to take a pic of.
Cadence 4 inchers. In the stock rear locations. Yep, rear speakers. I wasn't gunna do rears but I had a four channel amp. I just keep 'em turned down.
They are here. I screwed through them into the metal also. The crossovers are stuck in behind/beside them.
Simple.
My help. That usually isn't.
Good enough.
Some wiring has taken place.
Fits like a glove. The wiring has already been cleaned up a little and will be better when I get it tuned in.
At least it looks good. Like a factory option.
Have you seen this man? He loves the cawk.
Well todays seems to be a bad day to do any adjusting with volume, as I have a hangover. //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
But from initial playin around they seem to be OK. I'll get after them tomorrow when my head stops pounding itself.
Nice. I wish my s10 had room for 62 inches across! I have like 50...i ended up taking a sawzall to the jack holder to finish making clearance for my box! Alos, carpet does look pretty sweet.
koolwhipman
Busy busy busy...
koolwhipman
A western Chi-burb.
1991Brougham
AJ (ACE)
    Jun 28, 2026
Mike Mccabe
    Jun 28, 2026
