truck box for 2 10's
newyorkjets00
ok so the mounting depth on a kicker cvx 10 is 5 15/16.. i have 2 of these and i have a 93 reg cab s10 im 6'3 and wana build this box so im not sittin in my dash.. i know i have a couple post on here but bare with me i might make it worth your while //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif the box im using now is 8'' at the bottom and 4'' at the top but they subs are to deep and hit the wall when i sat them in but i think thats cuz the slant of the box so i needa fix that.. and i should have plenty room i can also use 1/2'' wood to save space. i would like a ported box mayb a amp rack in the middle but dont gotta have that.. so if u got some designs or something in mind lmk.. ill get dimm tomo but the box in there now is 44 across and 8'' bottom 4'' top and 15'' tall one divider with holes all drilled in it.. 20 bux at the pawn shop couldnt pass it up.
how well does that box fit with those dimensions that you gave? is there an extra inch up at the top maybe, or can it go up higher with a small top dimension? Can it go any wider?
I can draw something up in cad and figure out mounting depth and such.
I would just try and go with one 10'' ported. I have a ranger and the only way I would be able to fit two 10'' ported would be to build across the whole cab and all the way up to the window line. Then I wouldn't have anywhere to fit my amps. But if you find a way to fit it then do it..... maybe you should check out cardomain.com and look at the s10s on there. You might be able to find some good ideas. Good luck.
newyorkjets00
newyorkjets00
Lake Whitney
newyorkjets00
