i am at work so pics will not be available. i recently toasted my sub amp. it is a mb quart 1200.1D it was an ebay perchase so first i assumed it was a "b" stock amp sold as new. now that i am getting ready to buy another amp, i want to make sure that my wiring is ok so i dont go 2 for 2.
1. up front is stock battery, 95 amp isolator approx. 18 inches from alt. big 3 was done with 4 gauge because thats all i had available, no fusing on big3.
2. wire going from isolator to 2nd rear battery is 4 gauge, fused at 100amps. 2nd battery is an exide orbital.
3. power wire coming from 2nd battery to amps are:
a. 8 gauge to the mids/highs amp. amp is fused with 2 20amp fuses.
b. 4 gauge to the sub amp. one 80 amp inline fuse to the sub amp and
2 60 amp fuses on the sub amp.
all amps grounded to the battery with appropriate sized wire, battery grounded to the frame with 4 gauge. 2nd battery reads 13 volts with the car on and off. i do not get any dimming and i believe thats due to the isolator restricting flow?
does this seem like good enough wiring to get the job done? this is a daily setup and is ran on average about 30min to 1 hour everyday.
any help is appreciated
