tricking amp? 4Ohm sub, want 2Ohm load
mat3833
ok, well i just got a TMA 500.1 amp as my old amp blew. one thing i forgot about is that my sub is a 4 ohm single voice coil sub. i want to get the full 500 watts out of the TMA. at 4 ohm the powre output is 340W. is there any way to trick the amp into giving full power to the sub without blowing the amp? it is a monoblock amp, only one output.
i thought about wireing a 4 ohm resistor into the circuit, but decided against it. i figured id ask you guys.
Matt
thats what i figured. unfortunatly i forgot that i only had a SVC sub. implu and bass boost are maxed. i kno the sub can perform better, its just lacking the power it wants. "sigh" im going to check tomorrow and see if i can upgrade to the TMA 1000.1, its rated at 500W at 4 Ohms. thanks guys
Matt
Matt
just get a different sub, you'll probably need one soon when you blow it from having everything maxed out.
it is there for a reason though right...? its not a (blow this amp) dial
wow, i love how a simple post starts a flame war.... anyways, that sub will be fine with the imput and boost maxxed. say whatever you want.
Matt
Exact reason why I don't come on here very often...
R U serious?... Maxed out?... You don't see a problem?..
Do you have any idea what a potentiometer even is? Do you know what bass boost does ..... at all?.....
mat3833
mat3833
florida
Villeza1
