Trapped Bass!
gogo4
First My Setup:
In a 99' Cadillac De'Ville -
1x - Rockford Fosgate 1 farad cap
2X - Hifonix 1000 Brutus amp's (1 for each sub)
1X - Audiobhanh 400 (forgot model)
2X - 12' T1 Rockford Fosgate Subs
Pioneer Avic N1 Deck
All Round Polk Momo's 6x9's and 6.5's
3.5 cf` ported box facing trunk
Now this is my question:
I Have an armrest where i taken out the lether so when it flops down i get about 6x4' Hole for the spl... (helps actually a little)
(My trunk is super sealed and dynomated)
Today i was working on something and took off the backseat turned up a song and HOLY ****!!!
MY hairs tickled my nose itches and i can't breathe right. I think i wouldnt be able to light a match in my car its just stupid spl and bass all around.... about 3x louder then w/seat on.
Now how can i get this effect with my seat back on?
What would happen if i turned the box around and put it facing seat instead of trunk?
I need this sub's to hit to their max and i cna't help to think what potential they really have but i can't use it know what i mean =(
my only idea would be to look at the back dash and see if you can get rid of the back dash and replace it with some kind of metal sheeting with holes. imagine a fence in the back dash almost. just something that allows all that bass to get out of the trunk into the cabin. its gonna have to be all custom but see what you can do. should help a lot.
yea I have not being able to pull my back seat down.. everything would sound so much better
I'm actually working on a solution as we speak (I might try to replace my back seat with a seat from another similar car)
I took out my rear speakers in my BMW 325 and made a clear hole through some padding, now I have the ski hole completely open which is 8 by 10 and two 4 inch holes where the rear speaker used to be. Clearing out the rear speakers made about a 30% difference...which is huge. I don't know if this is posssible with that car but good luck.
You are also releasing a problem when you remove the seat. From reading your post, you said you sealed your trunk, and you have a ported box. You box still requires the movement of AIR to sound up to its full capabilities. You are starving your Speakers of air. When you moved the back seat you are allowing 2 things to happen. You are allowing more air flow, and you are also allowing the sound wave to come into the car. I have seen a few things done. People have cut 2 holes (8 in or so) in the back panel, and in turn PORTED their trunk. You would be amazed how many Cu FT of air those 2 12' subs can push. GIVE THE SPEAKERS SOME AIR.
Brahmas are nice. I have a 10" Mk1. Just a single 10 was enough for me.
19
880
Those look like decent cheaper options for sure and probably fine for some systems, but I agree, Audiocontrol has been making high quality stuff...
12
697
Defiantly. LOL 😂 It has never happened to me👀:poop:
6
753
gogo4
gogo4
Newark Ca
pavengmike6
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
