Trade Kicker ZX1500.1 and matching ZX650.4 for....
BassmentJack
Resident Douchebag
502
USA
These are mint amps. Come with all original boxes, birthsheets, paperwork, manuals, knobs, etc. both are 10/10 on each. NO FLAWS! AND NOT REFURBS!!These amps are the exact same dimensions for a really cool looking install. Now to the Nitty Gritty. The only trades I will consider are Sundown SAZ1500D & a Sundown SAZ100.2, or 100.4
Some other trades I may consider are a MINT, I mean MINT BNIB Memphis Belle. There are other large amp/sub combos I may consider.
you are clearly wrong. they are 20 inches long, check kickers website. the amps where not sitting evenly in the pics....RETARD! you must be blind
4-Channel ZX-Series Power Amplifier
Low Impedance Operation
SORT Protection Circuitry (Short circuit, Over-voltage, Reverse polarity, Thermal)
MOSFET Power Supply
KickBass: 0-18 dB @ 40 Hz
Built-In Variable Crossover: 12 dB High or Low-Pass operation (50-200 Hz)
High & Low level inputs
Custom tooled gold plated connectors
SAMS (Stereo And Mono Simultaneously) bridged mono load and a stereo load at the same time
Cast aluminum EndKaps
RMS Power Ratings:
120 watts x 4 chan. @ 4 ohms
170 watts x 4 chan. @ 2 ohms
325 watts x 2 chan. @ 4 ohms Bridged
Input gain control: Low Level (125mV - 5V), High Level (250mV - 10V)
Dimensions: 20" L x 10-1/8" W x 2.5" H
ZX Series Class D Monoblock Amplifier
RMS Power Output
4 ohms: 750 watts x 1 chan.
2 ohms: 1500 watts x 1 chan.
Gain and crossover frequency control
Protection light indicator
MOSFET Power Supply
Soft Start turn-on
Subsonic Filter
Protection Circuit
Remote bass control
Input Sensitivity (High Level): 250mV - 10V
Input Sensitivity (Low Level): 125mV - 5V
Active Crossover: 24 db/octave, variable 50Hz-200Hz, Low pass only
KICKQ Boost: Variable to +18dB
12db/octave subsonic filter defeatable at 25Hz
was never registered on the road so no, here in maine for a vehicle of that age all you need is a bill of sale. i still have original dealer...
406
441
932
BassmentJack
Resident Douchebag
BassmentJack
USA
king ranch
pfft
    May 1, 2024
pfft
    May 1, 2024
