town car trunk
thanks. i see that i have about 15 cubes but i understand the part about the width because the 15s themselves would need about 45w
better yet , since you havent bought subs yet. Why not 2 higher quality 18's. Its almost the identical amount of cone area , you wouldnt have problems with space , and it would be easier to get you impedance correct too because you wont be running a odd number of subs. And if you want my 2 cents i would check out the SSA XCON's.
Average cone area of three 15's is 2430 square CM , average cone area of two 18's is 2420 square CM. It's not enough to worry about honestly.
You can just stagger the subs to make them fit across the 45" width.
i already mentioned that ram , then i realized there is almost no cone area difference to benefit from. LOL. But he may be aesthetically set on the wow factor of cramming 3 15's in there instead of the norm of a pair of 18's.
You should use an adapter. You might gain some insight on a Town Car forum as well. https://www.installer.com/cars/by_car.php?carid=3402
As stated..A jumper wire from remote to Power on amplifier will be a nice little test to see if the amplifier is working. If it does, I would...
I agree with others, just buy the OFC. My last wiring was oversized CCA, and while it still works, and looked okay when I peeled the heat shrink...
84
BigAl
BigAl
birmingham,al
Bassin Buick
