Total Harmonic Distortion
Mboyle1145
Im curious how the percentages work and ehat it all really means. I have a aq1200d and about to install a small alpine 4 channel amp and im curious why they put two differnt power ratings one with 1% thd and 5% thd what does this really mean the more distortion the more power? im just curious what it means and how do you tell if your running the 1% or 5% or whatever percent that it states?
In general the higher the power (also lower the resistance of your sub-woofers) the more total harmonic distortion you will get.
Usually around .5%-1% is about where your ears will start to notice a difference in sound quality.
For sound quality, 4 ohm loads or higher have the best sound. Lower than that, you will start to get higher THD levels.
So when running my amp at .8 ohms ill have more power but have more distortion but i want really notice it that much basically?
Check to make sure your amp is .8 ohm stable first.
At any resistance under 2 ohms you are probably going to notice some distortion in the sound. How much will be dependent on the amp and how good your electrical setup is.
Personally I would not run any amp below 2 ohms, but I like SQ. If you are looking for SPL then go 4 it. lol
i see makes sense my amp is 1 ohm stable and alot of people run it .5 i checked with DJ and prorabbit my elctrical system is good and im going to do big three as well and im not going to go crazy on gain or head unit setttings ether. and im going for more spl than sq i have had aq set ups and its time to rattle peoples mirrors behind me //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
It means that if you are willing to accept more distortion, the amp can put out more power. As an amp gets up towards its max power the output starts to distort. It doesn't really relate to load impedance, unless you go lower than recommended in which case the number goes up. At 5% you can definitely hear it but if you're going for loud then there will be other noises that'll probably mask the THD anyway.
5% is tough enough to discern in highs. Especially on music. I very seriously doubt any of you can hear 5% distortion in a sub.
Depending on how good your computer speakers are, check this out and see if you can hear it. There's a little sound clip in there to see if you can hear the difference...
Depends on the volume you are listening at and some other factors. 2% is really noticeable to my ears at a medium/loud volume on mids/highs. But it also depends on the source of your music.
Mboyle1145
Mboyle1145
Houston, Tx
TaylorFade
