Torrent Help?
IDK I had to download a couple other programs because there's so many extensions that dameon doesn't cover...Power ISO and Magic Disc...plus for some reason Dameon just stopped working one day so I gave up on it. And yeah alcohol definitely sucks balls.
Oh and to help out, it sounds like your not mounting right...if you were mounting it correctly the computer would thing the cd is in already...
i'm kind of at my witts end with this, but now i'm determined to get it to work because i am now two gigs closer to my limit on oink because of this. if anyone with any kind of experience with this stuff, could write up a step by step on how to mount all the files, or burn them to a cd with details i would GREATLY appreciate it...
when I burn them to a cd, do i make a data cd or a bootable data cd? when i mount them in daemon, do i just right click a virtual drive, select mount, then select one cd? or can i mount all 3 cds to the same virtual drive?
Just burn them as a image file....if ur using Nero its in Backup section...."Burn image to disc"
What happens when u mount disc 1?
I had a Max Payne i dled and it had 3 cds....just mounted them as they installed...than it asked for disc to ok unmounted disc one and mounted disc 2.
If u have aim pm me...DatDudeBL...ill try to help
ok, i mounted in the install cd, and then it said "Rosetta was successfully installed, insert your language disc to continue" but then when i went to mount the first language disc, it brought up the windows box that said "This device contains more than one type of content, what do you want Windows to do?"
my mounting program is Daemon
If theres an option to run or install.....i forget whats all the options
Are you sure thats the install disk?
When you mount the first disk go to windows explorer and open the disks files see if theres a readme file or what not.....it should tell you all there is to know on that
Also whats the 2nd disk is it an .iso/cue/bin file?
If all else fails you can burn them all as image files and load them that way
the first disc has a .iso and a .pdf in it. the second disc is just .iso
This seems too difficult for you. why don't you actually but the real stuff and help a software developer pay his bills?
i'm not computer illiterate, i'm just venturing into unknown territory. torrents didn't make sense to me until someone taught me about them...
and $329 dollars just for a refresher course on my first class and some knowledge after that? seems a bit steep. i'm sure that programmer is doing just fine....
yne721
SWINE FLU!!!!
yne721
Maui/Detroit
Twistid
