Topic: please help me find 6 3/4" speakers!
  • 2
sylvr
abc
this is pretty much an extension of what i was asking in my origional thread:
http://forums.caraudio.com/vb/showthread.php?p=328267#post328267
my 02 lancer says it has a front speaker size of 6 3/4, depth of 3 and height of 3/4, but practically all i see are 6 1/2 sized speakers that *sometimes* come with 6 3/4 adapters. what do you reccomend would be the best speakers for me that would cost around 200 for a front pair?
heres some info:
i like to listen to rap and trance so if that helps...
so far i have a brahma 15" in the back so i want something that would work well with that and not be drowned out.
i really really don't want to buy a new amp at the moment so i want something that would sound decent off my head unit that has 52 w x 4 at 4 ohm max power and 23.2 w x 4 at 4 ohm rms. i know someday i will get an amp for them but for now i just want them off my hu. so yes, its a must that it will sound noticibly better than stock speakers both powered off head unit for now and be ready for a future upgrade in power later.
i know i want to do the installation myself so im mainly looking into simple plug in coaxials but i have heard of comps that you could have the tweeters attached to the woofer so yeah that would be great for now since i dont want to make any modifications to the car itself like placing the tweets.
so far im looking at something like these:
Kicker Resolution RS6c
http://www.sounddomain.com/shop/item.pl?sku=KICRS6C&vq_id=none
Infinity Kappa 63.5i
http://www.sounddomain.com/shop/item.pl?sku=INFKAPPA635I&vq_id=none
well that looks like it should be enough information; please let me know what you can and thanks for any and all help!
heres some info:
My saturn also calls for 6 3/4 inch speakers. Although not great, Alpine makes coax's and components in 6 3/4". Personally, I got DEI Neodymiums becuase they fit the shallow mounting depth. If you can find those for cheap, they would be a good bet.
444
Check out Sonic Electronix as well. They have some great deals usually and excellent Customer Service also. I like to buy my HUs /Head Units from...
324
998
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
sylvr
sylvr
abc
jemorgan85
    May 12, 2024
Brendon Jenness
    May 11, 2024
