To neone that can help me with shocks/springs??
turnstylez18
k...i just put in my sub and box in my trunk yesterday...and it was really heavy that it lowered the back of the car...the main problem is that when someone sits in the back..the rear wheel is almost touching the wheel..so i know i have suspension problems..anyone know exactly what to replace to fix this..and reduce it to come down lower..whats the most cost efficient way to do this? i really dont know much about cars..thanks...
k..my year of corolla seemed to have bad springs...some ppl say that i would have to get stiffer springs but most stiffer springs are for lowered cars...so if i get these springs..i would have to lower my car...
if the car is lowered with the new spring..will it still go down when i put the subs in? and can lowered cars drive in the winter?
well have you taken it to a shop? if you just took it to a local shop, and just ask them about it, and see what they think, most will just look for free. bcuz there is a chance that your springs are just worn and not stiff anymore. or you might have bad shocks. does it seem pretty bumpy? as for the same height im not sure cuz i always lowered my car. give a shop a call and see what they can do for you. hope that helps.
shouldnt if you get a good setup. i had lowered my car, and it was pretty low. could fit one finger pointing up in the front, and a full finger in the back, carried 4 people including me, and 2 10 inch subs, no rubs at all. the only thing was the exhaust occasionally hit the axles, but i just got that readjusted, it was easy.
if you jack up the back, and there are coil springs, just get coil spring extensions...you can buy them at most automotive shops. You jack up the car, and slide two per coil, one per side...it can raise the car, to keep from squatting down so far...
turnstylez18
turnstylez18
Toronto
Polecat
