To many choices
  • 2
youngblood77
Ok, new dude and qestions for help I have and this is no **** here is what I have in my garage waiting to be installed I am going with just one but lets have some help in desiding which ones..... here is amp info so can be a educated and productive thread.
Kenwood KAC-x812d
mono car subwoofer amplifier
533 watts RMS x 1 at 4 ohms (919 watts RMS x 1 at 2 ohms)
1-ohm stable (over 1,000 watts RMS x 1 at 1 ohm)
variable low-pass filter (50-200 Hz, 24 dB per octave)
variable band reject filter (40-200 Hz, 0ff/-6 dB/-12 dB)
variable bass control (-15 to +15 dB selectable for 60/80/100/200 Hz with selectable Q factor)
subsonic filter (0/15/25 Hz, 24 dB/octave)
A.M.S. (Amplifier Management System)for control of amp functions from compatible Kenwood receiver
AMP Information Display (voltage, current, temperature, cooling fan speed)
Class D design
2-speed cooling fan
gold-plated preamp inputs and outputs
Here are sub choices what I dont use will probaly sell but sound off on choice and maybe why you feel that away...
1 Vasonic 10 dual 4 ohm cheaper one
1 MA Audio 10 daul 4 ohm cheaper one
1 Kicker CVR 12 dual 4 ohm the one and only
4 Cheap ass BASS ebay subs (sound good for $100.00 for all in sealed box)
1 MA 8 in sub dual 2 ohm Their best and bad ass sub
1 MMATS 12 dual 4 ohm Bad ass best one they got
1 kewwood 12 single 4 ohm Mid range price sub
2 Kicker comp 10 older models just got new surrounds one them ? duals
1 Premier 12 super bad ass top of line sub, dual 4 ohms
I know that is alot, I got some pretty cheap and some from auctions at local storage place , I got 1 10 sealed box, 1 sealed 12 sealed box, but can get/make other boxes, I am not going for 1 block away bass just me and my love of sound, but SQ is main idea. I will post other stuff as I go one but start off with sub and move on from there.. Thank in advance for help Peace, love, and GREASE is the word
Alright sorry this took so long. Here's the update. I tried out all the sets of speakers, the black diamonds did not fit front or back. I think if...
23
5 ch amps can get expensive and most of the sub stage lacks power for a decent mid-sized sub. And end up running hot. Some times its best to look...
This is a little more money but well worth it from looking at the reviews. And it's Korean.
13
I wouldnt waste the time or money on OEM speakers to be placed back into any vehicle unless you plan to sale the vehicle and remove the after...
With half inch MDF, it's like 4.27cu/ft internally not including sub and port displacement. That's like 3.5 to 3.8cu/ft after displacement. You...
youngblood77
youngblood77
Republic, Mo
damanTO81
Brendon Jenness
    May 8, 2024
    May 8, 2024
