To close to call: Elevation Audio x or Re audio mx 12"
RumbleNTheTrunk
Both look like pretty solid subwoofers. Really havent ran the x yet to see how good it really can be but judging. I dont think the mx would be worth the 400 dollars(from a seller on here) seeing how I payed alot less for the elevation. to me most of these specs are just number but if you was to compare them which looks like the better some...im sure the x would be better for spl and mx better for sq.
t/s specs
Elevation Audio x12"
fs- 32 qes- 0.449 qms - 4.30 qts- 0.406 vas-34l xmax-32m effecieincy - 88.9db sd- .0539sqm re-2.6 ohm dvc 2 ohm rms power - 1500rms
Re audio mx 12"
Electrical Q Value -Qes: 0.503
Mechanical Q Value -Qms: 3.206
Total Speaker Q Value -Qts: 0.434
Free Air Resonance -Fs: 23.165 Hz
Equivalent Compliance -Vas: 59.0 liters
One-Way, Linear Excursion -Xmax: 22 mm
Efficiency - SPL 1W/1m: 83.5 dB SPL
Effective Piston Area -Sd: 480 cm^2
DC Resistance -Re: 1.4 ohm per coil
Nominal Impedance -Znom: Dual 2 ohm
Thermal Power Handling -Pe: 1500 W
Force Factor -Bl: 14.56
MX, it's highly underrated... //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
nG
same as the x...people have them things tons of power daily...im going to give it 2kw daily...x is more efficient so it would get louder of less power. but like i said the mx looks good tho. I really wanna try re...if i get the mx and i dont like it it's going up for sell that same day.
edit: seen a vid on ROE the mx looks awesome...plus judging by the specs it looks like it can get lower.
gotta give it more than one day
yea im sure i wouldnt do that...im sure i wouldnt be disspointed...but if i was to spend 400 dollars and it be crap id be pretty depressed...but i think majority rules that the mx is a really good sub. Most likely id keep the x and or sell it if i was to buy the mx and like it better....also I know someone selling a new 06 xxx for 600...I may be going that way if i have the money. Tommorow's my birthday
RumbleNTheTrunk
RumbleNTheTrunk
Liberty, TX
HotCarl
