TN1.1200 or RF R750.1
gtidriver77
Haven't built a system in a while so I need help choosing one of these amps. Going to run 1 sundown SA 10 not sure if it will be a 2ohm or a 4ohm ver. I've narrowed it down to a Soundstream TN1.1200 or the Rockford Prime R750.1. Would the Soundstream be to much for the sundown at 1ohm? or should I run it at 2ohms? The Rockford I would deff run it at 1ohm. Which one would you guys say to go with. It will be going in a 2011 VW Tiguan it has a 140amp alt and just the factory battery. With the car running I get 14.1 volts pretty steady. I just want to run enough power for a nice daily driver but I want a little headroom. I've seen the you tube videos saying both amps make the power but should I trust the amp dyno?
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
does that mean Cadillac is owned by Buick and Mercury owns Ford??
Who knew??
It's owned by Elipsion, power acoustic is the main brand.
So it's owned by power acoustic just like Orion is now owned by pyramid.
gtidriver77
gtidriver77
Denver, CO
MrFoca
