Tired of Pioneer 10's
iver729
I have a Phoenix Gold Xenon X600.1 amp powering two Pioneer TS-W256DVC Subs right now. It is my first setup and wasn't that bad in my opinion. The subs were a little weak and now I am looking to replace them. I want to use the same amp, any suggestions?
Sealed? Ported? Budget? SQ, or just as loud as possible off of 600W? Using same box? How much airspace available? Moving to larger subs?
Details man... give a few more details...
Arent those subs, 400 watt rms? if im not mistaken, i know the 12's are at 400 or 500. So you arent getting the full potential out of those subs in the first place.
I'm not to familar with these subs, but correct me if im wrong, a 600 watt amp can't power two 400watt subs (total 800 watt rms)
# Amplifier Type: Mono
# RMS Power: 600W x 1 @ 4 ohms
# THD at 4-Ohm RMS Power: n/a
# Bridged RMS Power: 600W x 1 @ 2 ohms
If you were to get two of those, one for each sub, it would sound much better. Nothing is really going to sound much better with just that one amp. Thats what I would definitely do.
http://www.sonicelectronix.com/item_1491_Phoenix+Gold+R8.0-1.html
Not exactly the same, but pretty close. Are those 2 or 4ohm voicecoils?
http://www.sonicelectronix.com/item_6720_Precision+Power+PPI+D2000-1.html
Sell the amp you have now and pick that one up if you can bridge those subs to a 1ohm load, that'll put 1000watts (thats prob pretty conservative for that amp as well). So that'd be 500-600watts per sub.
You would be wrong. Running 800 instead of 600 is going to gain like 1.25 dB (not counting power compression) at full volume. It will barely make any difference at all.
Also, the enclosure dictates how much power a sub can actually handle mechanically -- a 400w sub is rated to thermally handle 400w of power, but it may very well reach its mechanical limits with 300 watts in an optimum sized box.
x2 just take a 3kw rms rated sub and set it on your kitchen table and power it with a couple of 40.1's....see how long it sits there till it smokes //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
put the same driver in a box with the same power and it wangs. //content.invisioncic.com/y282845/emoticons/fro.gif.c695f1f814b01c4ad99fe7f8cccadd29.gif
iver729
iver729
Syracuse, NY
Cbass
