Thoughts on this setup?
After Looking through some reviews on certain dubs and amps I've came up with this duo of sub and amp but not sure if they will perform well together
What do yu guys think?
Links below
1 12" RE Audio SXX dvc 4ohm
Hifonics Brutus 2000.1d
If you guys can give me any other recommendations I'd greatly appreciate them...
I'm on a 700$ budget
Drive 2006 honda civic si-has factory a 8" "sub" and amp already.
Looking to make my car flex, listen to hip-hop type songs with a lot of bass..
**** really? What about incriminatir audio lethal injections or sundown audios?
Or should i follow other guys advice and get ab xfl's
ANY of those choices are better than the CURRENT RE lineup - xfl's are a really good bang for your buck...
All the subs are good options. I like the Lethal Injections - I owned one. The XFL is in a whole different class though, it'll take a TON of power and get loud and low in the right box (about 2 cubes tuned to 32-34hz) I currently have a pair of XFLs and I love them.
The phantom isn't a "bad" amp but I'd honestly take the Hifonics over it. It will do rated power or very near. Another good choice would be the PPI bk1800.1 - that would save money and give you headroom to do stuff like deadening and upgrading your electrical.
Good stuff guys and thanks for the inputs I'll look more into the American bass subs.
Who knows anyone here who can send me a good custom box for a single sub? Can only afford one sub at the moment.
Will I need to make any electrical mods to my car with this setup?
on a budget if you get 2 apsm 1500 at around $125 each and strap them you should be able to get clean 2k on it. and if you get dvc2 on those xfl you will be at 2ohm shish is strapped power for 2 amps
you could wire to 1 or 4 ohms ,your choice
Alright cool, I'm new to this scene so I'm learning as I go but I cross check the xfl max rms says 2000,
And the hifonics Brutus RMS power rating says "1ohm: 2000Watts x 1chan.
So If i wire the sub down to 1ohm it will receive it's maximum 2000rms power right?
Or Am I horribly wrong ha.
H2SER
H2SER
The toe
H2SER
