This may not exist but I sure hope it does...
Forget power handling. Just set your gain on your amp so it won't blow your subs... problem solved. You're not going to a find a sub anywhere near what you're asking for. I don't know what that little spot is you're screwing with in the picture, but it's a horrible location. If that's all you have to work with fine but, epic fail.
Its a storage compartment.
There is no room behind the back seats and no room under the seats unless you go down into the floor like that compartment.
between the location, box type, and the drivers you can fit in that box, you arent going to have much of a substage response.
I mean, there will be some, but for what you plan on investing into this, i dont think it would be worth it.
I could do the same thing without paying anyone but I honestly love the way EVERYTHING looks in the truck. I dont want to have to replace part just to make this work.
I have thought about that though haha
that truck is a sick *** ride, i drove my friends the other day....that ***** has some kick to it!!
Make the cutout a bit bigger, and fit a pair of these in: Dayton NS310-44 10" Run your amp at 4ohms with the gains down a bit to avoid stinky coils, or get a smaller amp. If space truly is a premium as you're making it out to be, there are plenty of tiny amps that put out ample power for a pair of these.
Here are the 8" versions: Dayton NS310-44 8"
And of course, the 12" version: Dayton NS310-44 12"
And here are some 12" Tangband shallow subs: WQ-1814S 12"
geonfreaq
geonfreaq
norfolk, VA
Wingman0121
BP1Fanatic
BP1Fanatic
