This is weird check htis out.
  • 4
QuadPioneer
Spinnin' Tracks on Flat
600
Canada
Im looking at building a front loaded sub box for my 4 12" pioneers. And according to winisp, its better to make two seperate boxes, or have a divider in the middle, to have two subs in there own chambers. And since im going ported at 38hz it made a pretty big difference.
I think its normally suggested to put subs in separate chambers, that way if one of them blows, the one that still works doesn't blow also if its a large box.
Originally posted by Tek I think its normally suggested to put subs in separate chambers, that way if one of them blows, the one that still works doesn't blow also if its a large box.
will also allow you to pinpoint the blown sub
not like its real hard to go back there and watch them to see which one is blown....but i guess you are right. they have their own air if they are seperate...rather then sharing air. technically one sub could use the other subs air....making it uneven. Even though usually the subs are identical and will use the same amount. Its not a huge deal...but its better to have seperate chambers.
Originally posted by Bumpin03 not like its real hard to go back there and watch them to see which one is blown....but i guess you are right. they have their own air if they are seperate...rather then sharing air. technically one sub could use the other subs air....making it uneven. Even though usually the subs are identical and will use the same amount. Its not a huge deal...but its better to have seperate chambers.
ok?? you got 2 subs in the same air space and one blows, HTF you gonna know which one it is by looking?? both subs are gonna be moving.
Yeah, somebody goofed. It was supposed to last 5. I have seen speakers fail at the solder joint on the cone under the black glue. But you are...
8
Sometimes the sound gets a bit lower, then gets normal again, only listening to FM radio. It does not do this when streaming music via wired Apple...
so an update: basically i got my 2nd car which i just installed a car amp kit and routed all the wires so i thought to myself lets take this amp...
5
Error was fixed by soldering their connector on mine, mine wasn't color coded (e.g. red - switching power, yellow - constant power etc.) It was...
6
QuadPioneer
QuadPioneer
Canada
pburt
saints747
    May 7, 2024
saints747
    May 7, 2024
Latest topics
